Fan info for you..
[sAn]Assasin
UK-Blackpool
I was running a thermalright ax-7 and a delta 80mm ehe series screemer..( real nice temps) but WAY to loud..
I have just fitted a Thermaltake Smart Fan 2 to the ax7 and lost 5c!!
The smart fans comes with: an adjustable rpm dial and a temp probe small enough to fit inside the ziff socket or where ever..
Mine is on the base of the cpu.. and with my barton 2500 @ 2.3ghz the smart fan never goes above 3k rpm.. and you carnt hear it!!
Just thought i'd recomend it..
Zoilo
Once Bitten, Twice Shy
L.A.
I've got the SF2 on an SLK-800 running full speed all the time and I don't go over 46C. ([email protected], 1.86V)
I can also run it past its specified speeds with the nexus multipanel, but it's too much for this fan and the hub gets way too hot, so I try to keep it around its specified speeds. The noise doesn't bother me after dealing with a 92mm Tornado.
