Maybe, my gf 256 sdr fan got loud after about 1yr of use. The blue orb will work fine if you want to replace it but it might block the pci slot next to it depending on the motherboard.
If you want strange noises then you cant beat the fan in my burner. ive has this thign for 4 years and now its makes REALLY WIERD noises... (its about 15mm)
Teenamax or something like that makes a thin one.
Its like $20.00 I think that is good enough for that video card.
If you go to the main www.overclockers.com web page and look in the bx cooler section you can find the correct spelling and a link to thier site.
