Fan Popped Out?
nsimbu
Just got a Orb today and after about 3 min of it running the fan stopped. When I turn it on now it doesn't do anything but if u kick start it a lil it will start spinning but very slow. Anyone know how or if its possible to fix this?
Xaotic
Very kind Senior
Greensboro NC
Preferrably, take it back and get another unit. Never trust a cooling solution that may fail at any time. You could try oiling the bearing, but I'd trust it less far than I could throw it. Replacing the fan or the unit is a better solution.
xhwfed
Australia
question.........
Are the orb fans any good?
i was thinking of buying one but i want to know i there any good
Other then the dodge one you got.... if i was you id take it back and get a replacement
N
nsimbu
Well for the short time it ran it wasn't that bad. What exactly does it mean by the fan "popping out"?
ThePunkGeek
Ontario Canada
try a new 3-4 pin adapter
or if your using a fan header on the motherboard get a 3-4 pin adapter or you could try another fan header.
sounds like the header is dead
N
nsimbu
What exactly is a fan header im new to all this? Other fans work fine on the connector on the motherboard if thats what your talking about. It just seems this fan doesn't move/seems like its not getting enough power to push itself.
IFMU
The Xtreme Senior Nobody
A fan header is the white connection on the motherboard you connect the fan too. Now if I remember right, you said other fans work on that header. So I would presume that its the actual fan itself. I would return it as soon as you can. Some places are bad about returns/exchanges. So better to get it done now then find out later you cant. But thats my 2 coppers.
IFMU
N
nsimbu
Alright i'll get a RMA from newegg and ask for an exchange. It also seems the fan touches the top grill when spinning so I presume its dead.
ThePunkGeek
Ontario Canada
newegg is good with exchages you should have no problems
