Results have varried quite a bit on fan stacking. The only way to know for sure is to give it a try. A couple of small zip ties should allow you to do the test.
What HSF are you using and what is the fan? A C2-566 is an easy cpu to cool. I used a pal 6035(stock fan) to run one at 1020mhz. If you are running to hot a better sink may be in order.
