Fan Question
dilosolid
Message i have a celeron2 566
and i have 2 of the same fan what if i put the fan on the back of the other will
i get better temp?
Well I am not 100% sure what u are trying to say, but if you are asking if stacking the fans on eachother will do anything, then the answer is bassicly No.
Hope that helps
sure, it will help. you won't see twice the performance as with one fan, but it does move more air. however it isn't worth it because it gets really loud. i put two slow 60mm fans together and they sounded like a 6800 rpm delta. now i just run one y.s. tech 60mm quiet fan (3800 rpm, 21 cfm, 28 dba) on my FOP38 (which i guess should now be called a FOP21). my proc is a celeron ii 700 @ 872, and the temps are fine (never above 100).
