Here is a problem I have no idea how to solve . Any hints/solutions will be greatly appreciated:
Given one regular case fan and one fan controller. The fan controller's connector has 3 pins corresponding to: G, 12V and RPM monitoring (???). The fan has only 2 wires: G, 12V.
Question: Is it possible to monitor fan's RPM? How?
My opinion is that it should be a solution. That's because the speed of that fan was previously detected somehow. The setup was the following: 3pin connector from the PSU (Antec True 430) on the mobo and the fan connected to the "Fan Only" molex. The reading was within the specs of the fan and was increasing with the temperature of the case (feature of the PSU).
Maybe it should also be mentioned that the fan controller is a CoolerMaster Aerogate II.
Thank you very much
Thank you very much
