- Feb 13, 2002
- In a Little Bowl
Seeing as I cant afford my window mod til I get paid I am gonna have to get on wth my fan mod.
Atm my temps for both my case and CPU gradually rise and enver stay on a certain level. This is obviously cos i am sucking in the warm/hot air with my front fan, cos there isnt a hole in the front facia to suck though. (also i need to tidy my wires but shh
What I was intending to do is clip out the grille bit infront of the case fan mounted on the front. Then I was going to cut a hole in the front of the facia and get a small bit of tubing to create a seal from the open air to the fan (so no hot air sucked in). however i didnt fancy sucking in dust and stuff (cos its on the floor) So i was going to put some fine mesh over this hole.
The question is (if you've managed to stick wiht it so far) is how much will this affect the efficiency of the fan? I know the perforated bit of the case will affect it cos its solid (in places), but this isnt really solid at all. Otherwise i will obviously have to get a fan guard thingy i assume.
Cheers
Bob
Cheers
Bob
