The 80mm is the outside dimension of the housing. IE each side is 80mm long. I have never used Radio Shack fans, though i'm sure they buy them from someone else. I have seen Nidec fans at Radio Shack. Nidec is not top notch, but should hold you for a while.
Hoot
