Fan size
J
jb
Guest
Sorry I have to ask , how do I measure my fan's size ?
Horizontally / vertically or
diagonally (corner to corner)
All I have is a tape measure which only measures in ft , in and cm . I'm not really sure about the conversion but I got these ruff estimates.
~ = about
~3in horizontally to ~80mm
~4.5in diagonally to ~120mm
My is guess that it's the horizontal measurement but I think this post will be easier than going to the computer store after work tomorrow .
Thanks if you...
1inch=2.54cm so 8cm=8/2.54 or 3.1inches
size is the square outside part not the circular fan part.
metric calculator here
What I really want to know is do you measure the fan size using the horizontal measurement ( _ ) , the vertical measurement ( I ) or diagnoly ( \ or / ) . All measurements were from the fan case not the actual fan .
3.125 in = 79.375mm ( _ or I ) horizontal or vertical
4.5 in = 114.3 mm ( \ ) diagonal
