Pennywise359
- Dec 25, 2016
Hello everybody!
Finally I got enough courage to step up from my corsair h100i gtx to a custom loop. My OC'ed to 4.6 ghz i7 6700 was always hot and i had to run fans on my corsair AOI at max RPM. With custom loop temps are slightly better but it is still hot and I hit 74c at max load. AlsoI have noticed that that fans speed does not affect my temps at all.
Does somebody have a clue what can be wrong? Could it be a bad CPU or internal thermal compound?
Here is my loop config
Rads:
Alphacool NexXxoS XT45 360 Full Copper
Alphacool NexXxoS ST30 120 Full Copper
Fans:
5x EK Vardar 2200 rpm
PumpRes combo:
EK-XRES 100 Revo D5 PWM + EK-RES X3 - TUBE 250 (204mm) upgrade
Water Block:
XSPC Raystorm Pro
Thermal Compound :
Noctua NT-H1
As i know this config should be an overkill just for single CPU and later on i was planning watercool GPU's as well...
Thanks for attention guys, i hope someone can help me.
Rads:
Fans:
PumpRes combo:
Water Block:
XSPC Raystorm Pro
Thermal Compound :
Noctua NT-H1
