fan tail for panaflo
baraka
USA
Is there any place that sells a 3 pin + 4 pin tail for panaflo fans? I know places sell the 4 pin or 3 pin tails but I want a combo so I can power the fan from the power supply but hook the 3 pin to the mobo to monitor fan rpm.
macklin01
Computational Oncologist / Biomathematician / Mode
Bloomington, IN
Most panaflo's I've seen don't have the third RPM lead. (I have 4 at home right now.) In that case, there's no need to have a fan splitter cable.
In general (if it does indeed have all three leads), I'd recommend getting the typical 3-pin tail and using a standard splitter cable, such as this one. You might also try svc and kdcomputers for such products. Good luck -- Paul
