thanx
Thanx for the response guys.... I knew I was going to need something heavy duty. I'm still shopping around for some parts... I'm trying to spend less than $100 on this project.
Although really, its just an excuse to get some gear for watercooling, and a chance to expand my list of expensive hobbies.
If you're interested in the AC design I'm tinkering with....
Ambient air will get blown thru a 7/8 copper coil. The coil will be submerged in icey water, a 5 gallon hexagonal fishtank. The copper tube's terminal end will blow right into my cpu fan duct. I'll use pipe insulation on the part of the copper coil that's above water. I think condensation on the inside of the coil will be a problem after a while, so I'll drill a hole in it for a plug, so that I can drain it now and then.
The second stage involves a pump(Maxijet 1200) and a second reservoir kept in the icebox of a minifridge. This will chill the water in the fishtank, and help keep the ice from melting so fast. This whole apparatus will exist outside of my pc's case and will be independent of my pc's psu.
I also plan on dyeing the water with the insides of a few highlighters so it will glow in blacklight.
I don't know if it will work at all... But if I can move air thru the submerged copper coil, it should get cooler than ambient. The fishtank will be right next to my pc, so the air won't have much of a chance to heat back up. I'll put a basin under the fishtank since it'll probably sweat onto my desk if I don't. I think having an ice-cold aquarium next to my pc will probably reduce the ambient temps slightly anyway.
Any comments are welcome...
The original thread where I posted and revised the design is Titled "Ice Water Bong for Air Cooling". Now I refer to it as the Cheapo-chill fishtank AC.
