- Oct 31, 2009
- California
Some guys say that you should install fans with more CFM than you really need, so you have some headroom if you cooling needs increase. Then you adjust the fan speeds to meet your needs.
That sounds good (no pun! ) but I'm wondering. Say I really need fans (for a triple radiator) that run at 1000 rpm. And let's say that I going to use Gentle Typhoon fans because a lot of guys recommend them.
OK, now which speed fan should I get?
How low can I set the fan voltage and still get the fan to work?
If the fan is running at say 9.0 V, does that mean that the fan puts out 75% of the rpm and 75% of the cfm? What about static pressure?
Is the fan noise also going to be 75% of the rated dBA (assuming I can believe the manufacturer's specs?)
Thanks for answering these questions.
x509
x509
