fanbus
the_par4d0x_
hiya,
i'm terrible atwiring up stuff could someone make me something like this
except with only 3 switches and not already in a drive bay. (I'm not putting it in a bay slot I'm putting it on my actual case face.
Let me know if anyone can help me out and how much it'll be.
aupilotxp
Danville, VA
hey
im not much for circuit panels and such either, but that model doesnt come pre-installed on that bay front...its just a circuit board with switches....you may or may not have trouble getting people to make stuff for you, but as with most modders...they will tell you that you need to do as much as possible on your own (thats the big point of modding), in which i agree. I do all mine by myself, but i dont usually make my own baybuses etc... however i do install everything myself, and paint everything by myself...it may be worth buying that, and drilling 4 holes instead of 3, and just stick it in and screw it on, unless you dont have enough room on the front of your case...perhaps you can re locate where you want to put your switches, and i guarantee you will find something else to hook up to that switch such as a cathode light or another fan that you dont currently plan on putting on your case...anyways...i hope i have helped
Marc
aupilotxp
Danville, VA
oh...one other thing....maybe you can move that temp sensor up to one of the floppy drives, unless you plan on using both of them...dont worry you'll think of something :p
