Fanless case?
coin
Denmark
any case can be fanless, just remove ther fans that are there :p The problem you will face is that if you are cooling everything with watercooling you are going to have to find a way to shift a lot of heat out from your radiators, without fans this may be tricky.
josh files
josh files
New Zealand
I'm getting a Zalman Reserator1 BTW. Instead of getting a P-160 and taking out the fan, was wondering if I could get a case without any fans. Don't mean anything like a heat sink cooled case, just a case thats supposed to have fans but doesn't. Do OEM case's come with fans?
