Fans For The Ax-7
augustwest
The Darkest Star
how about a YS TECH Adjustable 8CM cooling fan. Manual adjustable fan speed, VERIABLE SPEED FROM 800rpm to 3700rpm. 10.2CFM - 48.7CFM 18dBA - 39.5dBA? is 50CFM enough for some serious OCing?
i dont mind a loud fan. i would just like to have the option of quieting it down at times. that is why im thinking about the YS Tech. at its highest speed setting it gets 50CFM. will that be enough for serious OCing?
also does a delta fan have that whine when turned down with a rheostat? that is really f***ing annoying if you ask me.
if someone has one of the deltas with a rheo, let me now how it sounds when it is slowed down.
weaponx: you wouldnt happen to be using an AX-7 would you? if you are then let me know what your temps are with the YS Tech.
