- Mar 9, 2002
- united kingdom
i want to add some fans to my case but need to know how to cut the holes
rnpgrosz said:On www.hardocp.com theres a guide on making a blowhole. Check it out.
Ebonyks said:There are several ways. Some people use dremels which take a long time to use, and i don't reccomend. I personally like holesaws, which are basically an attachment to the end of a standard drill, makes it quick and easy.
NASsoccer said:
i agree. I use a holesaw because no matter what you get a perfectly roundhole and then i use the dremel to smooth the edges.
Only if you're not careful.Tecumseh said:A dremel is a terrible thing to cut a blow hole.
Dissolved said:
LOL linking [H] from the forums here isnt a good idea..
