- Feb 5, 2016
Good morning,
This is my first post to this forum but I wanted to introduce myself and share my new build I have planned. Parts are ordered and on their way. I hopefully will start next week. I am planning on using this as a build thread too.
On to the specs:
CPU: Intel 5960x 8-Core
MoBo: MSI GodLike X99
RAM: GSkill 64Gb (4x 16GB) DDR4 3000Mhz
GPU: EVGA Titan X Hydro Series (Pre-Installed Water Block)
PSU: Corsair 1200watt
Case: InWin 909 Black
Water Cooling: EKWB Components with 360mm Rad and D5 pump, 250mL reservoir, PETG 16mm OD/12mm ID Hardline, Pastel White Coolant
ThermalTake 120mm and 140mm White LED High Pressure Fans.
Storage: 1.2Tb Intel 750 series PCIe x4 SSD AIC, 1Tb Samsung EVO SSD, 2x 6Tb WB Black Series HDD
I think that covers it. I will be overclocking the CPU to 4.5-4.7Ghz depending on how stable it is.
I'm currently using 2 LG 27" ISP monitors but may upgrade to a 4K monitor in the near future.
This rig will be used for gaming, video editing, and orthomosaic/aerial map processing. I think it should handle anything I throw at it pretty well.
I have never done a hardline system before but have built a few soft tube cooling rigs. Should be a good time.
I'll update this thread as parts start to arrive and I start building.
Josh
Images of parts!
On to the specs:
Josh
Images of parts!
