Fast write, smartgart, smartshader, Trueform.
I had to install the hotfix for call of duty, for my 9800np. It comes with drivers too, and it has some options that I have never seen before.
Under smartgart tab it has set agp speed. it has 2x 4x and 8x. So, I set this to 8x cause I have an 8x card. After it made me reset after changing it to 8x, it reset back to default of OFF. WTF.
Under the smartgart tab it also has fast write on or off. I have no idea what this is if anyone can tell me what this is, and if it should be on or off please.
Under the 3d tab, then the custom settings tab for opengl or direct3d there is a tab for"smartshader". It then says please select the smartshader effect you would like to apply to your game. Then it has about 5 options to choose from. It has no effect, black&white, classic, inverse color, porthole, RGB cycle, and stylize-black&white. If someone can tell me what this is , and what to put it on, please.
Then it has a TRUFORM option too. No idea what this is, please help.
None of these have a right click "help" "what is this" thing.
EDIT-After I reboot to change to 8x fast write also resets to off.
