Dave65 said:
I want to change over to NTFS from Fat 32,can I do this without formatting the HDD?
I want to be able to password some files so other users cannot access these folders.Can this be done??
Thanks
if you have windows xp, it is done by opening the command prompt and typing in:
convert c: /fs:ntfs
if you want to do a different drive, just change from c: to whatever.
if not in win xp, let me know and i will dig up the steps for you.
by the way, you must have win2k, winxp home, winxp pro, or winnt to run in ntfs. if you have a different os on the computer; any win9x, system, it will
not read the ntfs partition. make sure you do not want to go back to fat32 because it's irreversible (you can re-convert back to fat32 using partition magic, but i wouldn't recommend it due to lack of reliability)
