Awesome! Still waiting for a couple items for my loop. Those cable extensions custom of off the shelf, and what brand are they? Looking for some with a pattern like that instead of just alternating.
Those are the exact cables I bought. Very good quality for the money, especially after seeing cable mod prices. They have a few different color combos to choose from too. I think they all have one 24 pin, three 8 pins, and two 6 pins. It was one 8 pin short for my build but you can't really see it up in the top left corner.
Thanks! My 8 pins are pretty much hidden with a 60mm rad and fans up top. Mostly worried about the 24 and 6+2. How do you like your res, I got a similar one but without the distribution panel (I'm using soft tubing anyway). Really excited to get it set up.
The distribution panel is awesome! Even if you got his normal 360 panel it's still great quality, just a little more limited with loop layout, and you might have to modify the case just a little bit to get the pump in the back. Just finished the build completely and got everything up and running. Heres a few crappy pics.
