- Aug 27, 2003
- Mississauga, Ontario
I have two 1.5TB WD drives, warranty void by now (tried, but over by at least 2-3 years). These two HDD's are in question for this post. I do have a SSD for the OS, a Raptor for games and a bunch of other big drives, including a 3TB external drive that I use for movies and it works still after all these years (knock on wood). Somehow the prices for these drives are not going down like they used to, I bought my 3TB external for less than $200, more than 4 years ago, and now the cheapest 3TB drive I can find is only half that price, ridiculous.
Anyhow, I have done a low level format and a chkdsk full check and both drives have bad sectors (the 1.5TB drives). One is a Green drive WD15EARS, the other is black/silver but also WD15EARS, probably from before the color coding that WD does now. The bad sectors however, they are under 1MB on one drive and under 2MB on the other, so tiny. Of course windows has put a block on them, and yes, I can put stuff on them, but after a while, even on the same day, the drive will hit the bad sector anyway, and slow down to Kbytes/second and won't allow a cancel (whether copying or watching), randomly. After this little crash and wait, the drive continues again but this repeats. Right now the drives are both formatted and empty, with chkdsk putting bad sectors in quarantine (lol)
So I figure it's toast but it occurs to me to do something, and want your opinion:
Originally I was going to ask if there is software out there that can map the drive for me and show me the sectors that are damaged, and then allow me to partition that part of the HDD off, not to be accessed at all (no letter) and assign a letter to the good part, whatever big I make it, whether 1.4TB or something smaller, just to keep the needle away from the bad sectors.
But then I came up with another way, which may be possible. How about I just do a half partition (fdisk or any other partitioning software), so 2x750GB, then do chkdsk and find out which half has the bad sectors, and the use the good half and assign it a letter. I figured since this is a half, a huge chunk of disk considering the tiny amount of bad sectors, the needle shouldn't go near the assigned visible partition. This way I would make two 750GB drives out of the two 1.5TBs, and even that is fine with me if it guarantees success.
But then I though, hey, why not continue this process, and then with the bad 750GB, half it again, and use the good half (375GB) and give that a letter, and put aside the bad 375GB. I could half it again to 185GB and maybe even again, and end up with 4 partitions per drive assigned letters, with the last 180GB or where ever I stop, not assigned, and containing the bad sectors.
Do you guys think that would do it? If not halfing all the way down to a few GB, then at least a 750GB and 375GB partitions with letters assigned, then the 375GB partition that has the few MB of bad sectors, leave it alone, not active at all, no letter, just empty non used partition, would that be ok? I'd be willing to give up 375GB per drive to do this if I could be 99.9% sure that those bad sectors will not bother me.
Any opinion on this would be greatly appreciated.
