System:
Athlon XP 1700
Epox 8K5A2+
256 MB DDR333 K-Byte RAM
80 mm Case Fan
Thermaltake Volcano 6Cu heatsink&fan
Maxtor 20 GB 7200 RPM ATA 133
Lite On 40x12x48 CDRW
Mitsumi FDD
Allied 450 W PSU (AMD and Athlon XP recommended).. dual fan
Chaintech Geforce 4 MX 440 64 MB DDR
Windows XP
Samtron 77V 17" Monitor
Ran through:
memtest
3dMark SE 2001
PC mark
Sisoft Sandra
Directx Diagnostic
All devices working fine, passed all benchmarks and tests with typical system expectations. MBM is reading nice temperatures (27 case and 40-41 CPU). Sandra and PC Mark would like one of my fans to move faster.... but its on and keeping nice temp.
Problems:
1) Occasionally/randomly , particularly on a restart to upgrade drivers, comp won't boot into BIOS and monitor turns off (fans etc continue to move Epox board has the C1 post code). Have flashed to newest bios... it was doing this before flash as well. POwer down for 30 secs and/or reset CMOS and things are fine. In bios boot up it may say CPU Clock change failed etc.... or a CMOS Checksum error.... sometimes no error. Can F1 past BIOS and have no problems and boot up fine many times.
2) 3.3 V reads 1.6ish in PC Health, Post and MbM. Heard this is an EPOX reading problem and not to worry. Plus I was told to get a new power supply to fix this (had a 350 W at first) and got the allied and same readings... although all rail readings are a lil higher and much more stable.
3) In Earth and Beyond quickly crashes to desktop. Was doing this in lobby test of 3d Mark too but I dropped back to 31.40 drivers and got through 3D MArk. Still crash to desktop in EnB. Have all newest drivers and bios and XP upgrades etc... Except the detonator which I dropped back to the 31.40 from the 40s. Did not crash to desktop in 3dmark or Neverwinter NIghts after going to 31.40. Which driver would be best then?? And should I do a XP reinstall and redo with default XP Drivers and see what happens? I seemed to have partially solved by moving from newest to older drivers. Yes video bios shadowing and video to ram cache are disabled. Have run geforce tweak to no avail.
4) My HD LED and Power LED do not come on ever. I heard there was an 8K5A2+ relationship to this.. could be the case??
5) Sisoft Sandra and PC MArk can't find my CDRW and FDD. FDD couldn't read a disc last night but has been fine... did not thoroughly check it (tired). CDRW Was having problems but is fine now (think it was a cable problem).
I'm running optimal settings with onboard LAN, RAID, with video settings above disabled. Think doing some setting changes to RAM may do something??? Going to failsafe kept 1 and 2 problems. Have not tried fail safe with 3rd problem.
Was getting bsods... particularly the loop error but that has been solved with the new power supply.... coincidentally?? Don't think I need bigger than an Allied 450 W... not enough peripherals.
Got all the parts last week... upgraded PSU yesterday and have round ATA 133 IDE Cables coming perhaps today or tomorrow to solve any cable problems.
How do I solve particularly the crash to desktop and the Bios won't boot sometimes (I think latter may have to do with changing BIOS Settings.. often happens when changing a setting... but happens sometimes when changing drivers on the restart which should not affect BIOS boot??).
Athlon XP 1700
Epox 8K5A2+
80 mm Case Fan
Mitsumi FDD
Windows XP
Ran through:
memtest
3dMark SE 2001
PC mark
Sisoft Sandra
Directx Diagnostic
Problems:
