FIC AZ11 HELP
ReFuGee DaWG
anyone have the same prob as i do?
i have to reintall my sound drivers every 2-3 boots....
i noticed though, that it works fine when i do a force reboot, then shutdown....
but if i let it shutdown the normal way, next time i bootup, the sound is messed up.....
thanks..
ULYSSES
I had the similar problems with a DURON 600 and a T-BIRD 650 on the AZ11. One thing that worked for me was to disable the onblard sound and install a sound card (this way you also get a game port).
Down the road I needed the sound card for another box I built. I used the onboard sound and installed WIN ME, and the problem has seemed to go away. The kids use that machine, and they haven't told me of any problems so it must be O-K.
