FIC Motherboard + Daughter board question
Sergecore
I recently bought a load full of computer junk at an auction and in there was a brand new FIC KZM 6120 Mobo, the kind that plugs into another board, and without it its useless. I tried emailing FIC about 5 letters and no reply from them. All I found on the net was this link and a couple of more useless links (at least to me) I would like to use this board sometime since I got a P3 chip but without the daughter board its useless. If anyone out there knows anything about where I can obtain the rest of the mobo please reply
Here is the Link with some info on the board:
I was unable to get any of the links to work. What does the connector look like on the board? Does it resemble an ISA bus card? It may be a single board computer designed to be used in a "passive backplane" such as an industrial computer.
You mihgt try searching the industrial computer suppliers, like ICS-Advent or Cyber Research for something similar. If it is a "passive backplane" board, they can supply you with the goodies.
I visited the Sites that you recommended, Thanks, And the board looks more like a consumer mobo, not a commercial. It has on board sound, 8 meg video, PS2 connectors, USB ports, 2 Dimm slots. No PCI or AGP, or ISA slots, no IDE, Floppy or COMM connectors. Its th size of a mini MB, Not an ATX.
Here is some info from the link that didnt work for you:
Intel Celeron 66/100 FSB, Pentium II Pentium III processor up to 733 MHz
Intel 440ZX chipset
2 DIMM; up to 256MB SDRAM
Matrox Calao G200 AGP with 8MB SDRAM
2 PCI, 1 ISA on riser card
2S, 1P, PS/2 Mouse, K/B, 2 USB
ACPI, APM, DMI, SMBIOS, PnP, Y2K compliant
On-board PCI IDE: Ultra DMA/33; DMA Mode 2 support
S.M.A.R.T. support
20-pin ATX power connector on riser card
Mini NLX form factor, 10.25" x 8"
The connector along the board looks like an AGP, with a little ISA connector near the end.
Sounds like a cute little board- it's a shame it has to be an odd configuration.
Good luck
Have you tried searching with "industrial strength" search engines like dogpile.com or google.com?
I have checked every page that I found with every search engine. Nothing. Just bios updates, useless q and a , and some other junk that was in Jananese. Nothing usefull. I didnt even find any computer brand names that use these Mobos. I guess that it will be collecting dust until i find something, if i find something. I posted several posts at diffirent forums, but this is the only one where someone replied! If anyone gets any ideas please post them, or email me.
