fill and bleed
daniel_dynasty
fill the system with ur solution/mixture. then let it run with the computer OFF. then as the bubbles rise refill it and let it 'bleed' again. this will take awhile
ukdan
uk
what pump are you using? most pumps need to be primed before startup i.e plenty of fluid in and before the pump. if not you could damage it.
