X1XNobleX1X
- Jan 15, 2016
This is what I have come up with over comments that have been made:
PC Case Gear - Shared Shopping Cart
1 x XSPC PETG Bending Rubber - $4.00ea
1 x EK Supremacy EVO X99 CPU Waterblock Nickel - $79.00ea
2 x EK CoolStream XE 480 Quad Radiator - $149.00ea
6 x XSPC PETG Tubing Clear 14/10mm 50cm 2 Pack - $6.00ea
1 x EK-XTOP Revo D5 PWM Pump - $129.00ea
1 x EK Ekoolant Pastel Concentrate 250ml White - $22.00ea
1 x EK RES X3 250 Reservoir - $69.00ea
12 x XSPC G1/4 Chrome to 14/10mm PETG Triple Seal Fitting - $6.00ea
1 x Alphacool 2 Way Ball Valve G1/4 Chrome - $9.00ea
Total: $718.00 - @pccasegear.com 19/01/2016
Edited by X1XNobleX1X - Today at 11:03 pm
As you can see, the build will be done in a 900D with rads both at the top and bottom basement.
- The purple line in the picture is the drain port.
