- Apr 1, 2003
- Florida
Ok got the verge assembled and running. using the l30 pump and maze3 block and the danger den gpu block. I noticed that when i flat out run it full bore, prime 95 and 3dmark it gets to 49c Idles at 42c with room temp of about 74 deg F. Does this sound about right? Im running my Barton2500 (1883mhz) at 2400mhz. 192fsb set to aggressive, with 5,2,2,2.5 memory 1 gig at 2.7 volts have uber bios set to 1.9(asus psot reads 1.88) and cpu set to 1.850. Video card core is set to 364.50mhz and memory set to 330.75mhz. Seems to be all the all in wonder 9700 can do.
. So how do the temps sound? before I was using slk800a and would get to 122 before asus cop shut down the pc. at 2400 but was able to run the slk at 2375. reaching no more tham 122f
