- Jun 5, 2006
- Beaufort, SC
Sup guys, I've been thinking about going with water for a little while, and found what I hope was a decent deal to pull me in. Right now I have the Zaleman 9500 on my cpu (Opteron 146~2.8 Prime), and two Evga 7800GTXs. The funny part is I have a 1000cfm blower as the front fan. My GTX's ran at 80C at load and I had to do something. Now they don't budge over 60c during artifact scan, but the blower is a little louder than I like.
I found on Ebay a Thermaltake system someone was selling. It has one CPU block (CL-W0010), two GPU blocks (Aquarius II), a single 120mm Fan/Radiator, one 5 1/4" bay reservoir, a 12v pump, a 210 flow indicator, a t-shaped connector for the temp probe, and the connectors for the tubing. I'll include pics below. From reading I see Thermaltakes not too high on the list, please tell me I didn't waste my money,lol. I got the set for around $50 plus shipping. Seemed like a good deal, but I have some concerns. Mainly, I wan't my video cards to run at a decent temp without having a wind tunnel in my room. I have my Opteron 146 OC'd at 2.8 prime stable and 2.9 system stable, but would like 3.0 prime stable. Currently at 2.8 it runs around 38c idle and 45 - 50c with prime95. It gets hot in my room, so that doesn't help.
I'm not sure the pump is adequate for the 3 blocks. If not, what would you suggest that doesn't cost an arm/leg.
Is this a decent system to use?
I have a pic below of one of the GPU block. It has some scratches on the copper surface. Should I wetsand it to smooth it out, or take it to a local machine shop and have them lap it? Or does it look ok for use?
Last, the connectors for tubing are 1/4". Will that Suffice for what I need. If not, is it possable to get bigger connectors for these blocks? I see on Frozencpu.com that they are avalible with 1/4" - 1/2" connectors, but didn't see where I could buy just the connectors.
I think thats all the questions I have right now. I've done a decent bit of reading on water lately, but any suggestions are welcome. Thank you guys.
Pics are as follows.
Heres my current setup,lol
Thanks guys for any help.
