Blueacid made one also:
BTW - these programs were designed to be used from a floppy disk, with subfolders "Console" (Contains FAH3Console.exe and client.cfg) and "servistl" (Contains the service installer)
Oh, and Wedo's registry file in the root directory (a:\)
Bare bones one:
Thats the basics...
Here is the one designed for emailing to people (basically it explains everything)
Blueacid
Bare bones one:
Code:
@echo off
cls
c:
cd \Progra~1
md folding
cd folding
copy a:\console\FAH3con~1.exe c:\Progra~1\folding\FAH3con~1.exe
copy a:\console\client.cfg c:\Progra~1\folding\client.cfg
a:\servistl\setup.exe
echo Press any key when the service install has completed
pause
cls
regedit "a:\fah.reg"
pause
@ECHO ON
Thats the basics...
Code:
@echo off
cls
echo This disk will automatically configure Folding@Home to run as a service
echo on your computer
echo You will need Administrative access to the system.
echo Also, bear in mind that the service install will only work on machines
echo running Windows XP or Windows 2000
echo This file created by Blueacid of Overclockers Forums
echo [url]http://www.oc-forums.com/[/url]
echo It will create a folder inside "c:\program echo files" entitled 'folding'
echo Then, it will copy the Console echo (FAH3Console.exe) and the config file
echo over to the computer.
echo Next, it will run the program to make folding run as a service.
echo Then, it will merge a registry file to the computer's registry, which
echo will make the Folding console take advantage of Gromac proteins (faster!)
echo All ready? (Press CONTROL+C to cancel!)
pause
cls
echo **** C O P Y I N G ****
c:
cd \Progra~1
md folding
cd folding
echo Copied.
echo Now the system will run a Windows program that will set up the computer
echo to run Folding@Home as a Service - this will make Folding@Home almost
echo invisible to the user of the computer, so they can't meddle with it
echo too much.
echo When the program gives you the four options as to how to 'set up'
echo Folding@Home, choose the bottom option of the four, for an Existing install.
echo Point the installer at c:\Program Files\folding\FAH3Console.exe
echo (or whatever looks like that)
echo Do *NOT* point it at Fah_core65.exe or anything that has the word
echo CORE in it!
echo About to run service installer
pause
cls
echo **** SERVICE INSTALL RUNNING ****
pause
cls
echo Now, this installer will merge some information into your registry
echo (this module courtesy of Wedo - also of Overclockers Forums.
echo Kudos to you, sir)
echo For those not up to scratch on folding terms, these settings make the
echo Folding Program take advantage of 'test' proteins, which tend to
echo improve the speed at which a computer folds the proteins, and also
echo you get more points for your work
echo For the more technically minded, this modification will make the console run
echo with the -advmethods and the -forceasm arguments.
echo About to modify settings...
echo (click OK when windows pops up messages about applying
echo the changes to the computer's registry)
pause
cls
echo Thats all done! If all went to plan, this system has been set up to
echo run Folding@Home automatically, as a service, with the -advmethods
echo and -forceasm arguments.
echo QUOTE - NASSoccer (Team leader of Team 32 [url]http://www.overclockers.com/[/url])
echo "
echo FOLD ON!
echo NAS
echo "
echo Please pay us a visit sometime to chat!
echo [url]http://folding.octeams.com/[/url]
echo Oh, and if you don't know what team number to use, a value of
echo 32 makes the computer fold faster, honest.
pause
cls
echo Oh - forgot :D You're probably looking to edit the client.cfg
echo file right now, aren't you :)
echo well, press any key to load it up.
echo Change your username appropriately (if you really really must) but
echo leave all the other settings alone unless you know what you're
echo doing........
pause
notepad c:\progra~1\folding\client.cfg
Blueacid
