- Sep 30, 2020
Hi guys!
I kind of discussed this question off-topic already in another thread at the Video Cards section earlier today, but I'm pretty much stuck, so I thought it would be better to open up a separate thread.
CPU: AMD Ryzen 9 5950X
MOBO: ASUS ROG Crosshair VIII Dark Hero (manual)
STORAGE: Samsung 980 PRO 1 TB, Samsung 960 EVO 1 TB, Samsung 960 EVO 500 GB, Samsung 960 EVO 500 GB
I have four NVMe M.2 modules, which I like to run on my new ASUS Dark Hero motherboard. However, the board has only two M.2 slots. At first I thought about buying the HYPER M.2 X16 GEN 4 CARD (manual), which allows you to extend with four extra NVMe's. The issue however, is that it only runs four of them, when installed in PCIe slot 1.
This basically leaves me with the alternative: Installing two NVMe's on the motherboard and using an adapter for the remaining ones in PCIe slot 3.
Issue
I found out that there are two types of M.2 slots on these 'dual M.2 adapters': M-key and B-key. The M-key being for high speed NVMe's, the B-key for slower SSD's. A LOT of these cards only allow you to install one NVMe module. If there are two M.2 slots, then it's usually to combine one NVMe module with a slower SSD module.
If it weren't for this M-key/B-key thing, this card would be just great. Also in terms of looks... Some of these cards are fully red or old school green or just ugly: https://www.amazon.com/Adapter-advanced-solution-Controller-Expansion/dp/B07JKH5VTL
When I look back at the ASUS Hyper Card, it seems like all four M.2 slots are from the type M-key. Which basically is a nice solution, however: It has a fan and I don't know what effect this x4 x4 x4 x4 card will have on the performance of the rest of the system (GPU in slot 1 for example). I'm a newbie in terms of the technicals, so I did my best to find an answers online, but I couldn't really narrow things down to what I needed to know. From what I understand it should be fine as long as I would be running only two modules on this card? Besides a GPU in slot 1?
The 'overkill' ASUS Hyper GEN 4 Card would be a nice solution, but like I said: It would be great if I could get a card which uses a heatsink instead of a fan.
The thing is though... the dual M-key M.2 adapter cards that I'm able to find are a more expensive than the 'more simpler' ASUS Hyper GEN 4 Card. Most of the M-key AND B-key adapter cards are cheap. Varying from $10-50. The 2x M-key adapter cards seem to be jumping from $150 up to $600. While the ASUS Card is around $85.
Am I missing something here? Is there an easier name for the card that I'm looking for? Do I have to face the fact that I'm stuck with a fan since NVMe's produce more heat? You would think that there are cheaper 2x M-key M.2 adapter cards. I mean... the ASUS Card has 4 slots that run at x4 and are all M-key. It costs $85. Why would a more simpeler brand charge way more for only two M-key slots?
I hope I was being clear enough
Thanks!
Issue
Thanks!
