Hello everyone!
So this is my first watercooling build, ordered this pump combo https://www.ekwb.com/shop/ek-xres-140-revo-d5-pwm-incl-pump
I set it all up, had a few things I didn't consider, a right angle and barbe fitting for the radiators etc.
Anyway, got it all setup, set the pumps PWN connector to the motherboards CPU fan header. Upon turning it on, I noticed the pump ran at 100% use. filled the entire system, ran it for a few minutes. Nothing.
I switched the connectors around, tried a few different headers. But every restart yielded the same result, it simply wont regulate the speed.
What can be done here? Is the pump faulty? Its quite loud
