Hey guys, need some much appreciated help here, making my first build here and mostly i have just changed the hard drive, optical drive and memory on a computer before, so no technically skilled here so bear with me a little and i'm probably gonna need help building this thing. I'm under a $1500 budget right now, so i checked your guide for the 1000+ and 1500+ budget system and kinda went from there.
Antec Twelve Hundred V3 Black Steel ATX Full Tower Computer Case $159.99
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K $314.99
GIGABYTE GA-P67A-UD5-B3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $259.99
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9 $99.99
CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible ... $89.99
SAPPHIRE 100312SR Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity $274.99
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $89.99
ZALMAN CNPS9900ALED 120mm 2 Ball Low-noise Blue LED CPU Cooler $64.99
OCZ Vertex 2 OCZSSD2-2VTXE60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD) $124.99
LG DVD Burner - Bulk Black SATA Model GH24NS50 - OEM $18.99
So with that plus shipping I'm over by like $25 or something, maybe i should take out the optical drive, does that build work? missing anything? i would like your opinion on the psu and the cpu fan cause i just got that in there from the reviews from newegg, maybe something cheaper but that still does a good job?, i got the ssd in there but maybe should take it out and buy a another 1tb one? what do you think of the gpu? i saw you guys recommended the hd 5870 but i thought this 2gb one was better and actually cheaper, probably I'm wrong. With this I'm broke so it would be a month or month and a half before i can buy the monitor (i want a 24 inch one) and keybord/mouse.
