- Nov 22, 2016
Hello,
This is my first build and my first post, So Hi everyone and please keep in mind that I'm only 2 weeks old in the WC business
I've wanted to do that for quite some times now and the release of the 1080GTX seems a good moment to actually deep in WC and try to upgrade my current system (a noisy fan cooled one) to a silent watercooled tower.
I've been browsing all the web about watercooling for the last 2 weeks and I've compiled a list of items that I have and that I will need to buy to make it happens.
So any feedback on this build will be much appreciated.
My aim is to keep my mother board, CPU,PSU and RAM, and change everything else.
I'm looking to have something really quiet, with, in the center of it, a GTX 1080 (gygabite).
Target fan RPM (radiator) is 1300RPM, with enough power to go higher if the heat rises.
Target liquid flow is 1-1.3GPM.
Estimated TDP (with a confortable error margin) to dissipate is 277W.
Estimated PSI resistance of the loop is 3.5PSI.
Recommended PSU for the whole system is 460W (my current PSU should be fine apparently).
Target DeltaT is +10° Celcius.
From this site (http://forums.evga.com/Review-of-the-EKXTOP-Revo-D5-EK-D5-PWM-G2-pump-m2497845.aspx)
the pump should be able to perform well above 1.3GPM with 3.5PSI.
So here it is :
General components :
CPU : Intel I7 3770 (already owned)
RAM : 2*8Gb Corsair (already owned)
PSU : Corsair 600 CX 80+Gold (already owned)
Motherboard : MSI Z77MA-G45 (already owned)
CASE : PHANTEKS Enthoo Pro Boitier Blanc https://www.grosbill.com/4-phanteks_enthoo_pro_boitier_blanc_window-672977-informatique-boitier
Fan Control : Phobya - Fan Controller TPC http://www.aquatuning.de/luftkuehlu...ontroller-30watt-each-channel-single-bay-5-25
Watercooling :
Radiator : Radiateur EK-CoolStream XE 360 https://www.ekwb.com/shop/ek-coolstream-xe-360-triple
Pump
+ Reservoir : EK-XRES 140 Revo D5 PWM https://www.ekwb.com/shop/ek-xres-140-revo-d5-pwm-incl-pump
GPU WB : EK VGA EK-FC1080 GTX G1 - Nickel / Plexi https://www.ekwb.com/shop/ek-fc1080-gtx-g1-nickel
CPU WB : EK-Supremacy EVO BLUE Edition https://www.ekwb.com/shop/ek-supremacy-evo-blue-edition
Fans : EK-Vardar F3-120 (1850rpm) x 6 https://www.ekwb.com/shop/ek-vardar-f3-120-1850rpm
Liquid : EK-Ekoolant EVO UV BLUE x 2 https://www.ekwb.com/shop/ek-ekoolant-evo-uv-blue-premix-1l
OR
EK-Ekoolant Pastel BLUE (concentrate 250mL) x 2 https://www.ekwb.com/shop/ek-ekoolant-pastel-blue-concentrate-250ml
(With distilled water)
Tubes : Mayhem Soft Tubing Ultra-Transparent Riot Ultra Clear Tubing - 10/16
Fittings : EK-ACF Compression Fitting 10/16mm - Elox Black
Extenders : EK-AF Extender 6mm M-M G1/4 - Nickel x 2 (to link T-valve , T-splitter and pump)
Valve : EK-AF Ball Valve (10mm) G1/4 - Nickel https://www.ekwb.com/shop/ek-af-ball-valve-10mm-g1-4-nickel
Splitter : EK-AF Y-Splitter Rotary 2F-1M G1/4 - Nickel https://www.ekwb.com/shop/ek-af-y-splitter-rotary-2f-1m-g1-4-nickel
Jumper : EK-ATX Bridging Plug (24 pin) https://www.ekwb.com/shop/ek-atx-bridging-plug-24-pin
I'm now lurking the merchant sites to get the best deals.
But before spending almost 1700$, I'd like to have an external though/advice about my system.
I may have overlooked something stupidly evident. If so please tell me
There may be some parts that can be improved or replaced with better ones. I'll be glad to here about it too.
A friend of mine is going for the same build, so I prefer to be sure !
Thank for any help.
PS : As you can see I've been looking almost only at EK parts. I've looked to Alphacool or Koolance but until now I found there price/product details to be better.
I can change this. I'm not EK exclusive
So here it is :
Watercooling :
Pump
OR
Thank for any help.
