First Build - Please take a look
Stacka
St. Louis, MO
I'm getting close to purchasing the parts for my first try at computer building. I've done a good amount of research and this is the list I have came up with:
-KingWin Black Aluminum Case
-Antec 430 Power Supply
-Asus P4C800-E DELUXE motherboard
-Pentium 4 2.8 GHz 800MHz
-OCZ performance Series PC-4200 (512x2)
-Western Digital 120GB 7200rpm
-SAPPHIRE RADEON 9800PRO, 256MB DDR
-Creative Labs Sound Blaster Audigy 2 ZS
-Thermalright SLK-947-U Copper Heatsink w/ Tornado 80mm
-Artic Silver Ceramique thermal paste
-Lite On Black 52x32x52 CD-RW Drive
-SAMSUNG 3.5inch Floppy
Looking for any good opinions on what I have, and how you think it will run/oc.
Thanks
9mmCensor
Disabled
Banned Camp
Welcome dude!
REplace the Thermalright SLK-947-U with the SP-94 (unless you plan on going to an AMD setup) and unless your deaf get a fan controler for the Tornado.
and the 2.8s are fine if you get the good MO stepping
for a few xtra bucks you can get a truepower 480 or the one with lights (go shiny!)
and for only like 40 bucks more you can get a
9800XT
so if you need to adhear to a budget get a less expensive CPU and a better Graphics car and some cooling and power.
S
Stacka
St. Louis, MO
Wow, thanks for the fast replies.
Taking a look at some of the replies, but I'm wondering about one thing.
Is there a definite difference between the 9800pro and the 9800xt. Is it worth the ~40-50$ price climb?
