First Build
Crazye2000
building my first PC and would like to know if all the parts are compatible and sufficient. Just want to make sure the PSU will have enough PCI adapters/ATX for CPU, Case will work with GPU and connections on MOBO, etc. Help and pointers would be a appreciated.
LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
Item #: N82E16827106289
Return Policy: Standard Return Policy
Protect Your Investment (expand for options)
$17.99
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148697
Recover Your Data(expand for options)
-$30.00 Instant
$109.99
$79.99
ASUS SABERTOOTH 990FX R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
Item #: N82E16813131877
Return Policy: Limited Replacement Only Return Policy
-$10.00 Instant
$189.99
$179.99
ASUS PCE-N15 PCI Express 300/300Mbps Transfer/Receive Rate Wireless Adapter
Item #: N82E16833320074
-$33.00 Instant
$59.99
$26.99
CORSAIR Builder Series CX600 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
Item #: N82E16817139028
-$10.00 Instant
$10.00 Mail-in Rebate Card
$79.99
$69.99
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
Item #: N82E16820231428
Return Policy: Memory Standard Return Policy
$62.99
Microsoft Windows 8 64-bit (Full Version) - OEM
Item #: N82E16832416550
Return Policy: Software Standard Return Policy
$99.99
COOLER MASTER Seidon 120M RL-S12M-24PK-R1 Water Cooler
Item #: N82E16835103179
-$5.00 Instant
$30.00 Mail-in Rebate Card
$74.99
$69.99
SAPPHIRE 100354OC-2L Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 CrossFireX Support Video Card
Item #: N82E16814202025
Return Policy: VGA Standard Return Policy
AMD FX-8320 Vishera 3.5GHz (4.0GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor FD8320FRHKBOX
Item #: N82E16819113285
Return Policy: CPU Replacement Only Return Policy
-$20.00 Instant
-$15.00 Combo
$15.00 Mail-in Rebate Card
$414.98
$379.98
1
AMD Gift coupon: Bioshock Inf. + Tomb Raider
Item #: N82E16800995146
I dont see a CPU...that is pretty important!
That said, I am a little bit worried about that cooler. Especially if you plan on getting an FX CPU and overclocking it. That cooler isnt better than midgrade air IIRC. If you want an AIO cooler, grab a Corsair H80 at minimum (if you plan on overclocking).
As far as the PSU, all modern PSUs come with 24 pin and 8 pin for the CPU. It comes with 2 x 6+2-Pin... (Found at the website or newegg.com)
Its under the GPU ED a AMD FX-8320 Vishera going into a 990FX Sabertooth! AJ.
+1 On up grading the water cooler those series 8xxx chips make quite a bit of heat, plus also take a chunk of voltage to OC them as well!
Ha! Thanks ajay... there wasnt a space there so I didnt catch it! :)
Yeah, FX CPU = more cooling if overclocking. ;)
Thanks this is what I ended up doing,
Qty Product Description Price
Order #: 211209918(shipped via Super Eggsaver (4-7 Business Days))
1
Rosewill CHALLENGER-U3 Black Gaming ATX Mid Tower Computer Case ,comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top ...
Item #: N82E16811147060
$69.99
$59.99
Subtotal $59.99
Tax $0.00
Super Eggsaver (4-7 Business Days) $0.00
Order Total $59.99
Order #: 211209898(shipped via Newegg 3 Business Days)
1
SAMSUNG DVD Burner SATA Model SH-224BB - OEM
Item #: N82E16827151256
$17.99
1
$62.99
1
$174.99
1
$139.99
1
$79.99
$69.99
1
Microsoft Desktop 400 5MH-00001 Black USB Wired Standard Keyboard
Item #: N82E16823109232
$29.99
$19.99
1
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel ...
Item #: N82E16835103099
$37.99
$34.99
1
Rosewill RTK-002 Anti-Static Wrist Strap
Item #: N82E16899261005
$4.99
1
Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148840
$109.99
$74.99
1
PowerColor AX7870 2GBD5-2DHPPV2E Radeon HD 7870 GHz EZ Edition (Tahiti LE) 2GB 256-bit GDDR5 Video Card (UEFI ready)
Item #: N82E16814131487
$244.99
1
Rosewill RNX-N150PCe (RNWD-11011) IEEE 802.11b/g/n PCIe 2.0 Wireless Adapter Up to 150Mbps Wireless Data Rates WPA/WPA2 (AES, ...
Item #: N82E16833166047
$21.99
$14.99
1
$99.99
1
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Item #: N82E16813128514
$149.99
$137.99
1
DISCOUNT FOR AUTOADD #77886
-$139.99
Subtotal $958.88
I just wanted to be safe lol haha, First Build man. So decent build then.
Ya I know, but when messing around with 1000 equipment, you tend want to be safe as possible so I wont damage anything. 5 bucks, it isn't much.
I have never used one... just dont wear cotton socks and shuffle your feet across a carpeted floor and the first thing you touch is a component. :p
LOL, I have to ask.. what is up with that quote in your sig, and how did you find a 8 year old thread to quote BS1?
well I'll be on wood floor and table so I should be well grounded, some people recommended the wrist band. Just wanted to be prepared. How does the build look.
build looks fine outside of the wrist band. :p
(I KID I KID!! Get if you feel you need it) :thup:
Mutha **** another wasted 5 dollars...... could of got me a BIG mac, love my cholesterol..money well spent.
Haha hey how difficult is the installation of the CPU, well actually I am concerned about the delicacy, like bending pins,etc. whats you perspective on the topic?
Be careful... dont force it in, it should 'drop' so to speak, right in the socket. If its off, LIFT it out, dont try to 'slide' it around for fitment.
