i was gonna make a really similar one to ChrioNs block, 1/2 outer channels and 1/8 middle channels. On my mill, 1 turn=1/16in. i got a single turn off and it messed it up, so i had to make it EXACTLY like chrions
the only diff is prob the channel depth, and the outer look. i used a 1/4inch copper bar as the base
heres some pics
(click the pic to access folder with more)
you see an extra hole... ignore it i marked my holes by scraping my caliper on the aluminum, there was lines from milling it down a little....... and yeah..
i cant wait to get the tripple channel thing in the center! my temps are down a bunch! The temps are around the same as the Type-S block, the Type-S was 44c level, this one is jumping between 43 and 45c
heres some pics
