This is my 2nd ever PC build, the first being done in 2008. I originally planned on AIO for both CPU and GPU but then decided to go custom loop for both. I've watched dozens of videos but none break it down to the specific parts needed to build the loop. I think I have everything accounted for but I'd like some help before ordering.
Build components that matter:
Loop parts list:
- Case - Phanteks Enthoo Evolv tempered glass
- CPU - i7 8700K
- CPU block - Phanteks PH-C350I_BK
- GPU - EVGA 1080 GTX Hydro Copper
- PSU - EVGA 750 G3
- CPU block - 2 fittings
- GPU block - 2 fittings
- Top radiator - 2 fittings
- Front radiator - 2 fittings
- Pump - 2 fittings
- Reservior - 2 fittings
- I am going with PETG 12/16 tubing, so based on my above parts list does this mean I need 12 12/16 compression fittings?
- Is it easier to go with a pump/res combo, or separate res and pump units? I think it may look cleaner having the pump in the basement of my case so it is out of sight, but if it makes things harder I can instead go with a smaller res and do the combo.
- I would like to add an extra drain line near the pump so when I do a flush it will make life easier. What do I need to tie this into the lines near the pump?
- Can I get good cooling with just 1 rad or should I go with 2?
Loop parts list:
- 1 x EK-RES X3 250 RGB (Reservoir)
- 1 x EK-XTOP Revo D5 PWM - (incl. sleeved pump) (Pump)
- 1 x EK-CoolStream SE 360 (Slim Triple) (Front rad)
- 1 x EK-CoolStream XE 360 (Triple) (Top rad)
- 6 x EK-Furious Vardar EVO 120 (3000rpm) (Rad fans)
- 1 x EK-HD PETG Tube 12/16mm 500mm (2pcs) (Tubing)
- 1 x EK-HD Tube D.I.Y. Kit 10&12mm (Tube bending/cutting kit)
- 12 x EK-ACF Fitting 12/16mm - Black (Compression fittings)
