- Feb 22, 2009
Last month I picked up a 10980xe. I also have a EVGA 1080 Graphics card Overclocked. I have an Corsair 850W PSU, 3 X 3000RPM Noctua Fans, one 6000RPM fan, a sound card and a couple of drives. I am coming from a i9 7900x where I didn't have this problem.
I have been working on my overclock and noticed that I can run almost every test but small FFTS. The entire time, I thought it was because my overclock was unstable.
I had a theory that my system power supply was pushing the limit, so I purchased a Kill-a-watt. In testing, a low overclock could hit about 740-760 watts. I was surprised, but I figured my 850 would be just enough. When I try to run P95 SFFT, the system just shuts down and reboots. I figured, I would lower my OC as low as possible.
I continued to lower my OC from 5.3, lower and lower until I eventually got to [email protected]. When I ran P95 SFFT, my Battery Back up APC began to scream, I was hitting +915 Watts on the Kill-a-watt directly at the APC. Quickly I exited P95 and the noise stopped.
So in fact I am exceeding my Power Supply's stated wattage and my APC's ability to supply battery back up under load.
So to the question: Since I normally will not be running P95 small FFTs and/or software where this would need that much power, am I safe to stay on this PSU, and has anyone else ever run into the problem that their PSU has limited their overclock?
