not sure how but i deleted the first post in the other thread so mods can delete that anyways heres the improved list of parts
the pc will be used primarily for gaming and photo editing of RAW files in lightroom, as well as 1080p video editing
my budget is around 1300 but if theirs a component that's totally worth the extra im willing to stretch it to 1500 (but id rather not
id like this pc to age better than my current pc which is about 6 years of gaming without to much trouble on the frame rate side of things, this last year or two have shown me its time to build new (along with my 7900gs dieing to put a nail in the coffin)
someday id like to hook my pc up to a 1080p tv primarily for steams big picture for console ports
id also like tri monitor gaming/desktop environment ive had dual for the longest time and i love it
need at least 6 usb spots most being usb 3.0 preferred (although not critical)
Case
i already have this antec 900 two mid tower case http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058 which has a giant 200mm fan on top 2 intakes in the front and 1 exhaust with an optional side fan near the acrylic window
CPU/MOBO
id like to do overclocking, enough to keep me movin and grooving over the years (which may mean higher than 1080p editing/rendering) i was thinking the 3570k overclocked http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
-$189 at microcenter
as well as this ASRock Z77 Extreme4 LGA 1155 Z77 ATX Intel Motherboard which has all the usb ports id need and as well as the ability to update my audio to HT quality with the optical audio http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293 -84.99 at microcenter (deal is z77 with intel processors is 50$ off)
GPU
evga gtx670 ftw 2gb, id honestly like more vram for future proofing but i have heard it comes at a cost of framerate not to sure. comes with borderlands 2 which id be happy to get http://www.newegg.com/Product/Product.aspx?Item=N82E16814130787 -$407
PSU
just a power supply with enough plugs power and stability, efficiency is somewhat important to keep the electric bill down (but the other features are more important specially stability) http://www.newegg.com/Product/Product.aspx?Item=N82E16817139022 -$135 on sale
SSD/HDD
hdd i was thinking maybe this seagate drive but unsure as i cant seem to find a popular fast (7200rpm) drive without horror stories behind them for a good price. im looking for 1-3 tb for under $150 and no slower eco drives i want 7200http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
the SAMSUNG 830 256gb ssd is one of the most exciting pieces in this build as its been the pc bottleneck for ages. important to be fast and stay fast, longevity/quality is important here as well as support from the company and owners incase a problem occurs (its popular so i doubt id have to much trouble finding help)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147135 -$218 on sale and comes with adapter bracket
Ram
ram is something im weak in deciding as i dont know how to read what good timings and speed are so let me know about this one in particular CORSAIR Vengeance 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) http://www.newegg.com/Product/Product.aspx?Item=N82E16820233246 -$90
DVD/Blu ray drive
dvd drive just has to work without a hitch and burn without problems, considering a blu ray drive for backups and to watch a box collection of harry potter in the future but other wise not a huge movie buff but i want to be immersed in visuals if i do become one. but for now just for harry.
lite on drive http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276 -$20
and a cable for it and the hdd http://www.newegg.com/Product/Product.aspx?Item=N82E16812270093 -$3.50
OS
windows 7 64 bit pro as i dont want to be limited to much in functions by windows especially since id like to learn more about operating systems as i would prefer a career in computers someday (although not sure what role to play yet) http://www.newegg.com/Product/Product.aspx?Item=N82E16832116992 -$140
Cooling
i picked the antec kuhler 620 http://www.newegg.com/Product/Product.aspx?Item=N82E16835209049 -$68 out of fear and horror stories of the corsair h80 so i could use help deciding on this one as i know the h80 is better when it works properly
i was also thinking of getting some Arctic Silver 5 and was wondering your thoughts on Arctic Silver Arcticlean Thermal material Remover & Surface Purifier to get the compound off the waterblock http://www.newegg.com/Product/Product.aspx?Item=N82E16835100010
Case
CPU/MOBO
GPU
PSU
SSD/HDD
Ram
DVD/Blu ray drive
OS
Cooling
