hey guys i have been reading through all the information on how to start on getting started on water cooling. i have everything thing in the cart i think i need just trying to figure out what size of radiator will fit in my case. i have the cooler master hafx and i seen a lot of configuration on the case when it comes to radiators, i am looking for a slim radiator because i don't have much room to work with and im planing on just using the two 200mm fans on top to pull the air off the radiator if that works at all because im doing a cpu+2 gpu build. here is a list i got so far:
reservoir: https://shop.ekwb.com/ek-dbay-d5-pwm-mx-plexi-incl-pump
cpu: https://shop.ekwb.com/ek-supremacy-evo-nickel
gpu: https://shop.ekwb.com/ek-thermosphere-nickel x2
gpu block: https://shop.ekwb.com/ek-fc-terminal-dual-parallel-3-slot-plexi
standard fittings
have not decided on tubing size yet
if you need anymore info just let me know
standard fittings
