- Nov 17, 2015
I am building my first nas, and wouldn't mind someone to tell me im either wasting my time and money, or if I am on the right track... My goal is to have a 2TB build for 500$...
Looking to go the micro ATX route since the motherboards for mini ITX, which I found, are so much more expensive for the sata raid... I would like to raid 5 for more data protection (... I know this is not a replacement to data backup, I already backup anything important
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128731
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819117374
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822236343 (X3)
Picked the mobo because of the extensive sata III slots, for expansion of sata raid in the future, as well as the lga 1150 socket for if I ever need to beef up my cpu... but for starters, I thought the Pentium dual-core with 3.2 GHz would be a nice place to start just for getting this started... thoughts? I went for a 53W power design, which is the lowest I found for intel without spending 200$ on an i5...
I am not going with ecc mobo or memory, because this is just for my own personal use. I will be the only person accessing, at most 2 machines at a time... it will mostly be used for plex anyways... I do not think I need any error correcting, since im not on an enterprise level...
and the hdd's, im going with 3 of those for the full array in raid 5. how do the WD red compare to blue or green drives in the nas? I haven't found much evidence in reviews or to much credible evidence to steer me away from getting the cheaper drives for my data, since this will be running 24/7...
so, tear me apart, or tell me im on the right track. the total rig ive shown comes to 493$. I already have a case this is going into, and a power supply (a 300W mini ITX ps, with a 24 pin for the mobo, I am assuming this will work!
