First step taken...
johnyew
Hong Kong
I went to my local junkyard looking for radiators and found 2 small engine oil coolers. It's about 2 120mm fans wide and about 1.5in thick. Bought both of them for HK$200(US$25):D
I am planning on using Peter's Gemini waterblock and an Eihem 1048. Do I connect both of them in series or in parallel?
Thanks.
The idea of using a couple of radiators comes up on a
regular basis. There are all sorts of variables that
complicate the choice. What happens to water flow
in the two configurations. What about turbulence in
the radiators? (You want this.) What happens to the
deltaT in both configurations?
You might get someone to "guess" if it is better to
go serial or parallel. Why don't you test it both ways
and report back to us what you find?
Good Luck.
