Hi Everyone,
I've recently installed a water loop but I'm running into issues and I'm scratching my head trying to diagnose the problem. Figure I'll turn to more experienced heads.
Firstly - Here are the components
All the parts are from Thermaltake
So here's the run down. I pulled the closed loop system I had on the computer and began installing the open loop. Once it was all set and down, I put some coolant in the fill port and then fired the pump on. I continued to add coolant until the reservoir was about 80% full after shutting it off and on several times.
Now the issue, I have a huge air pocket at the pipe leading from the radiator back to the pump (the final leg). I've tilted and twisted the computer all which ways trying to get the air out. It's gotten better but still there. Here is the biggest issue I have, I've stressed tested the computer and all the cores get above 50c and the computer starts stuttering. Clearly something isn't right here, the water cooling isn't cooling. Could it be the air bumble? I don't see any other in the lines.
Here's what I've done thus far to try to fix it. I've removed the waterblock and wiped away all the thermal paste and reapplied a pea size spot (i went overboard on the initial install). OH one last thing, I left the system running for 18 hours and there have been zero leaks.
PLEASE HELP ME!
- R480 radiator
- Pacific W2 water block
- PETG hard tubes
- Pacific PR22 pump+reservoir
PLEASE HELP ME!
