- Jan 8, 2002
- Boulder CO
I am not sure if this is just me but i have heard stories about how using dremels are so incredibly hard to do and such. Because of this, instead of making my own case window, i bought a lian li pc65 side window for my pc68 (only 30$, 5$ more than the DIY window kits). Anywho, I am in the process of a super duper case mod wich requires me to use a dremel. I first tested out the dremel on my old black metal case i had. I drew a triangle with a sharpie on the back and cut it out in around 15 minutes. For some reason, everybody says lian lis are easier to cut then metal cases but i disagree. Anyways, Since i purchased the lian li side case window, i had and extra side of the case that i wanted to practice on before i go and mod the rest of my case w/ my dremel. It was so easy! What i did was before hand, made with a marker a kinda square (the lines were not straight) on the back of the case. I just traced that out with my dremel and walla, i was done. It took me probably 5 cut off wheels to get through but i think i did a pretty decent job. With some rubber molding, you would not even be able to tell the minor imperfections i have in it.
