- Mar 10, 2017
Hi everyone
It was just yesterday I started looking in to overclocking for the first time after buying a new GPU (AMD RX 470) and realising how easy it was to increase the frequency of it, so I started looking in to CPU overclocking and found this forum
At the moment I have an AMD FX4100 (3.6Ghz default (200 x 18)) and read some guides about overclocking it
After a few hours of Prime95 tests, playing with the multiplier and adjusting voltages (I read the max for Bulldozer is 1.5V), I now have my CPU at 4.5Ghz (200 x 22.5) with 1.4V with temps below 35 on an hour test
But can't seem to push it any higher than this
Increasing the voltage to 1.425 or higher DECREASES the frequency my CPU is running at for some reason
I have the following things disabled in my Motherboard (ASUS M5A97 EVO) settings following a couple of guides I found:
Turbocore
CPU Spread Spectrum
PCIe Spread Spectrum
EPU Power Saving
CoolNQuiet
C1E
SVM
Core C6 State
APM Master Mode
And I have CPU Core Activation enabled
Hope this provides the info you guys need!!
<3
Turbocore
CPU Spread Spectrum
EPU Power Saving
CoolNQuiet
C1E
SVM
Core C6 State
APM Master Mode
<3
