Hello All !
I have built a few gaming rigs but this is my first custom water cooling loop. After a few days of installing everything I am concerned with the temps I am seeing. They are not by any means "bad" but I expected them to be much better. Maybe my expectations were too high so I am hopping someone with a equal amount of hardware can share their temps or tips.
The rig: http://i42.tinypic.com/9q9v6q.jpg
CPU: FX - 8350 (STOCK No over clock)
Motherboard: Gigabyte fx-ud7
Memory: Kingston hyper x blu 12gb
GPU: 2 x 7970 in crossfire
PSU: InWin comander 1200w
Case: Thermaltake Mk-1 Chaser
3x1080p 23" monitors @ 5760x1080
Water cooling Loop:
Res: Swiftech Maelstrom
Pump: MCP35X Pump Connected via PWM set @ 4500rpm
Rad #1: 400mm Phobya with 2x cooler master 200mm fans pulling out top
Rad:#2: XSPC 120mm rad with 1x 120mm fan pulling out back
Extra fans: 200mm fan puling in from front of case, 120mmfan pulling up from case (case is elevated)
CPU block : XSPC Raystorm
GPU Blocks: XSPC New Design Raystorms
Tubing: 1/2 in OD 3/8 ID UV blu
Liquid: SIlver coil and distilled water.
Layout: Single loop - RES>Pump>400mm>CPU>120mm>GPU1>GPU2(in series via XSPC bridge)>RES
No Air. Bleed for 24hours moving case around everything runs whisper quite.
Temps: Ambient room temp 26 c Hot in Texas right now
Water Loop temps (via res):
Idle: 29.5 c
Prime (20 min): 35.0 c
Furmark (20 min): 38.0 c
Battlefield 3 multi player (20 min): 41.0
HWMonitor:
Idle: CPU 19 c / GPU 40 c (Probably needs 10c offset)
Prime: CPU 38c
Furrmark: GPU 51c
BAttleifled 3: cpu 45 c - GPU 57 c
Coretemp (w/ +10c offset added)
Idle: 30 c
Prime: 48 c
Battlefield 3: 55c !!!!
MSI after Burninger:
Idle: GPU1 40 c / GPU2 38 c
Furrmark: GPU1 49 c / GPU2 51
Battlefield 3: GPU1 57 c / GPU2 59
The conclusion I have came to with the little experience and tons of research I have come across has led me to believe two completely different things.
1: Some people with fx 8350 and 2x 7970s have way better temps even overclocked which leads me to believe something is wrong.
Or
2: Some people I see with a Fx850 and 2x7970s have almost the same temps as me which leads me to believe maybe the cards plus chips in the same loop mean that while they are all being stressed I will have higher temps even with 520mm worth of rad space.
Thanks in advance to anyone who can help me out, basically I don't know if i should add more rads, fans, re-mount heatsinks etc.. if it's not going to get much better than this.. i'd hate to rip everything apart (again) and make things worst than they are. I'd like to OC only my gpu's in the future but it seems that a $800 WC system should give me that freedom, or am I just expecting more than science will allow.
Water cooling Loop:
Idle: 29.5 c
HWMonitor:
Prime: CPU 38c
Furrmark: GPU 51c
Idle: 30 c
Prime: 48 c
Or
