Okay, so I'm making the jump to watercooling since the comp is moving to my room but I don't want to sleep with my loud fans...
I'm building part by part, I bought a L30 pump, Swiftech MCW5000 block, '86 Chevette HC, reservoir out of PVC piping...
I'm going to be putting the items in a wooden box that will sit under my case, its only about 16" to the CPU from where the pump will be.
Now, I'm using 4x 80mm fans just pushing air through, with a shroud just for air seal. Will this work better than 1x 120mm (the HC is 160mm by 160mm) and a shroud? They are silent so no worries about the noise.
I'm going for 1/2" ID tubing, no problems with that right?
Is it okay for my to have my reservoir, pump, radiator all on the same level? If I decide later to get a bayres, will that impede water velocity?
Also, what are the right way to aline things?
Pump -> Rad -> CPU -> Res -> Pump
Is this bad? If the res is up beside the CPU should I change anything? Also, if I decide to get a GPU block can I put it in the same loop?
Thanks a lot for any help!
*OOPS*
Can a mod move this to the right forum? My bad :/
*OOPS*
