Thank you in advance to anyone who takes the time to read this massive post.
I am using a cosmos 2 case so space is not an issue.
I am unsure if i should do a single loop or double loop so I have lists for both. I have read conflicting information on this and would like more input.
I also am unsure of the quality of the parts i picked and would love suggestions as to better alternatives if they exist.
I am unsure if this is the best combination of parts I could get.
What would be a good fan controller able to control at least 11 fans?
First off the computer I am planing to show what i am in need of cooling.
[PCPartPicker part list](http://pcpartpicker.com/p/WGMF) / [Price breakdown by merchant](http://pcpartpicker.com/p/WGMF/by_merchant/) / [Benchmarks](http://pcpartpicker.com/p/WGMF/benchmarks/)
Type|Item|Price
**CPU** | [Intel Core i7-3970X Extreme Edition 3.5GHz 6-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80619i73970x) | $1003.98 @ SuperBiiz
**Motherboard** | [Asus Rampage IV Extreme EATX LGA2011 Motherboard](http://pcpartpicker.com/part/asus-motherboard-rampageivextreme) | $414.99 @ Newegg
**Memory** | [G.Skill Ripjaws Z Series 32GB (4 x 8GB) DDR3-1866 Memory](http://pcpartpicker.com/part/gskill-memory-f314900cl10q32gbzl) | $239.99 @ Newegg
**Video Card** | [EVGA GeForce GTX Titan 6GB Video Card](http://pcpartpicker.com/part/evga-video-card-06gp42790kr) | $1019.99 @ NCIX US
**Case** | [Cooler Master Cosmos II (Black) ATX Full Tower Case](http://pcpartpicker.com/part/cooler-master-case-rc1200kkn1) | $280.00 @ Newegg
| Generated by PCPartPicker 2013-05-15 00:49 EDT-0400 |
Now comes the cooling.
1. Single loop
a. res
i. Bitspower Water Tank Z-Multi 250 Inline Reservoir (BP-WTZM250P-BK) or
ii. EK-MultiOption RES X3 250 - Liquid Cooling Reservoir (6 Total Ports)
b. Swiftech MCP655-B 12v Water Pump w/ 3/8" Conversion Kit (317 GPH)
c. Tubing
i. Masterkleer PVC Tubing 1/2" ID / 3/4" OD - 10ft Retail Pack - UV Pink or
ii. Tygon B-44-4X 1/2" ID (3/4" OD) - "Non-Porous" Smooth Tubing with Mayhems uv pink
2. Duel loop
a. 2x XSPC Laing DDC Reservoir Pump Attachment w/ MCP-350/355 (No Fittings)
b. Tubing
i. Pink
1. Masterkleer PVC Tubing 1/2" ID / 3/4" OD - 10ft Retail Pack - UV Pink or
2. Tygon B-44-4X 1/2" ID (3/4" OD) - "Non-Porous" Smooth Tubing with Mayhems Dye - 15mL - Pink
ii. purple
1. Masterkleer PVC Tubing 1/2" ID / 3/4" OD - 10ft Retail Pack - UV Purple
3. Parts used in both options
a. Koolance CPU-380I Intel Liquid Cooling CPU Block - (No Fittings)
b. Rads
i. Black Ice GT Stealth 360 Radiator
ii. Black Ice GT Xtreme 140 Radiator - Black
iii. 2x Black Ice GTX Xtreme 240 Radiator - Black
c. Fans
i. 7 fans (4packs) Corsair Air Series SP120 High Performance Edition High Static Pressure 120mm PWM Fan - 2 Pack (CO-9050014-WW)
ii. Akasa 140mm x 25mm VIPER PWM Fan w/ Hydro Dynamic Bearings (AK-FN063)
d. Fittings
i. Bitspower G1/4 Thread 90-Degree Rotary 1/2" ID x 3/4" OD Compression Fitting (BP-90R3CPF-CC5)
ii. Bitspower G1/4" Silver Shining Dual Rotary 45-Degree Compression Fitting CC4 For ID 1/2" OD 5/8" Tube (BP-45R2CPF-CC4)
iii. Bitspower G1/4" Thread 1/2" ID x 5/8" OD Compression Fitting (BP-CPF-CC4)
iv. Bitspower G1/4" Matte Black T Adapter (BP-MBTMB) (drain lines)
e. Misc
i. IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip
ii. Phobya HeGrease Extreme Thermal Paste - 3.5g
iii. Koolance Threaded Rubber Funnel - G1/4" Thread (LIQ-FNL)
Single loop order:
res-pump-cpu-360-140-gpu-240-240-res
Dual loop order:
loop 1: res/pump-cpu-360-140-res/pump
loop 2: res/pump-gpu-240-240-res/pump
Type|Item|Price
1. Single loop
a. res
c. Tubing
2. Duel loop
b. Tubing
i. Pink
ii. purple
b. Rads
c. Fans
d. Fittings
e. Misc
Single loop order:
Dual loop order:
