I've read as much as my brain can absorb (and its starting to feel mushy), including some very good posts on how to choose parts for a loop. Even though it did an excellent job of educating me as to the fundamentals of why things work the way they do in a loop and what to look for, I still don't have enough data to decide on a pump
My loop will consist of (in order):
Phobya G1/4 Inline Temp Sensor Coupler
Bitspower Galaxy Universal RAM Module Liquid Cooling Block - 4-DIMMs - Clear (BP-RAMS44-CLBK) Cosair Vengance Pro (4 DIMMs) (just because)
Swiftech Apogee XL Extreme Performance Universal CPU Waterblock - Acrylic (Intel / AMD) i7-4790k
Swiftech The Komodo NV-LE Full Cover VGA Waterblock w/ Backplate (KOMODO-NV-LE) reference 780ti (EVGA 2884)
Aquaero 6 XT
Black Ice Nemesis GTX 480 Radiator
FrozenQ Liquid Fusion Dark Blue Helix Reservoir
Bitspower G1/4 Thread Flow Sensor
Pump (TBD based on need)
First custom loop and I had to dive in to the deep end...weeeeee!
I plan on using Primochill 1/2"OD acrylic tubing (UV blue). Probably an excessive amount, too.(after reading a few posts on it, the last section before the pump will have matching regular, flexible tubing to avoid cracking from vibration.) The NZXT Hue will handle the non-uv lights, the MB the Noiseblocker M12-S1 fans (6dbA; .36w/.003A @12V; 34cfm), the Aquaero 6 XT will handle the pump(s), any fans the MB can't (unlikely, given that 1 header could handle 30+ M12-S1 fans), and the UV lighting.
This Enthoo Primo will be a thing of beauty!...eventually
A few loose ends...
I can see I have a possible flow impedance of 6.1 PSI or so (can someone confirm this?), so I'm looking at dual pumps (expected). I also wanted to run my pumps at or below 60% to minimize noise and prolong their life expectancy. Given this, what pump(s) would be recommended?
I'm also not married to those fans. I'd like a silent machine, but with the Aquaero, I should have enough control over my fans to get that silence.
That leads me to the radiator. Most of the components that generate heat are watercooled, so air inside the case should be relatively cool. The case itself can support an insane number of radiators for its price. 120.4 up top, 120.3 on bottom, 120.2 in front, a 120.2 on the side and a 120.1 in the rear for effectively 120.12! Other configurations exist too. instead of the 120.2 in front, you can replace the 120.3 for a 120.4 on the bottom, but you lose 120mm2 of surface area. The bottom area is deep enough for a Monsta in push/pull without sacrificing anything more than you would if you wanted to put ANY radiator there (1x 120mm fan). The top can take a 60mm thick rad in push/pull too! Did I mention I love this case?
Is 120.4 enough for those parts, and have I chosen a good radiator? How much does radiator placement matter? I'd prefer not to (unless specifically told otherwise) put a rad on an air intake, as this would lead to warmer air temps inside the case - or so common sense would say.
As I said, my mind is kind mush about this (information overload), and I would appreciate any concrete tips or suggestions.
This project is still in the planning phase, with the first purchases likely 18-24 months out. I do plan on a complete build log when the time comes though (and yes, I do know I'm planning WAAAY in advance. Need to save up!)
Aquaero 6 XT
A few loose ends...
